APPS issues
I just put a vp44 on my truck and got it running but it idles at 1000 rpm but when I floor it it’ll idle at normal rpm. With the key on I tested all 6 wires and they all have right around 5v. Unplugged the tps and it idles fine obviously but what should I be chasing at this point? Codes are p0123 p0113 p0118 p01693 x2 p0236 p0237
Time to replace the APPS sensor. Make sure to get a Timbo's APPS and don't try to adjust the voltage. This could be what you've done with voltage adjustment.
59 minutes ago, njraymond98 said:
But why would even the grounds have 5v??
Possible the sensor ground is shorted to sensor ground? Is there any APPS wiring mods?
As for the P0123 code...
Possible Causes
5-volt Supply At APPS Shorted To Voltage (Engine Running)
APPS 5-volt Supply Circuit Shorted To Voltage
APPS Signal Circuit Shorted To Voltage (Engine Running)
APPS Return Circuit Open
APPS Signal Circuit Open From APPS To ECM
APPS 5-volt Supply Circuit Open
PCM (APPS) Circuit Shorted To Voltage With The Engine Running
PCM (APPS) Short To Voltage With Ignition Key On
APPS Open Between PCM And ECM
Open APPS Circuit
Accelerator Pedal Position Sensor (APPS)
Engine Control Module
