Miss at idle
I'm betting there's a misalignment yet.  The way I like to do injectors is put injector in, pop in crossover tube, tighten down high pressure line (that way the injector can still rotate in its bore to fully interface with the crossover tube) and then put injector hold down in and torque.
3 minutes ago, trreed said:
If you're going to be loosening the 19mm nuts completely, it'd be better for you to pull the line to the side and pop the crossover tube out and completely pull the injector and re-seat.
I would then have to strip the the apps intake and vp nuts as will wont i??
You would have to pull the APPS out to get to the #1 isolater bolt.  But there is enough play in these lines that they can be pulled to the side without permanently deforming, allowing access to crossover tubes.  I usually do this one at a time.
Will he need new copper washers then if he losenes injectors.
 one other thing I found helpful is to put oil on the nut threads and where it touches injector line to keep it from binding.
9 minutes ago, Ronniemx3 said:
I will just strip it all out again tomorrow and re do it all.. so put the injectors in then cross overs then tighten the hold downs and do up the HP lines??
I drop injectors in, put tubes in, put hold down straps on and snug them very little 10in/lb maybe, then I put all lines on and snug them about half way, then I torque hold down straps to 90 in/lb, then snug lines rest of the way. Everything is well oiled.
Edit
Make sure none of your crossover tubes are nicked on mating surfaces
Edited by Dieselfuture
Injectors in, crossover tubes in, HP lines tight (maybe cycle tight and loose three or so times to ensure proper seating) and then injector hold down.
