- Replies 4
- Views 3k
dripley 1 post
JAG1 1 post
01cummins4ever 1 post
piñon&juniper 1 post
Popular Days
Here's the photo essay... A sad day in February, 2016 It was a slow topple over the edge, and there were no impacts on the frame or running gear, so I
Welcome pics and projects make great threads
Hello everyone.
I joined a while ago and I’m finally getting on here. I have a 2001 2nd gen 24v work truck, mainly stock 5-speed war horse with 370K on it. It’s the successor to a similar 1998.5 unit that I rolled off a slippery mountain a couple of years ago (see my profile pictures). Both trucks were acquired at a little over 300K and are my first foray into diesel land. I’m fully committed to making at least one run forever.
I am now cab swap veteran, having replaced the rolled truck’s body with a nice clean quad cab (upgrade) from a 1998 gasser with a blown engine that I scored on Craigslist for cheap. I changed over the hood, fenders, cab, and all the cab interior, wiring, dash, and diesel specific soundproofing, and everything works great. That truck now belongs to my neighbor. I can post pictures and details from that process if anyone is interested.
My current truck, bought as work truck after the wreck, is now getting its first replacement NV4500 and clutch at about 370K (that seems like a long run for a clutch... I have all the service records from the original owner...). I'll be looking at the forums for hints and info on the removal and replacement procedure, lubricants, and anything else. Lubrication was the downfall of the NV4500 an now I'm replacing all the other fluids as well, so I'll be looking for sound advice on what to use where.
Since the truck is hove down for the time being, I'm hitting all the deferred maintenance I can, including: new power steering pump and lines, new radiator and hoses, fix coolant leak at oil cooler (I think), shocks, damper, camshaft position sensor, new injectors, rear wheel seals, and more I can't remember. I'll hit the forums on those topics as well, but if anyone wants to draw my attention to a standout article, please do!
Onward,
