V2 latest update MPH/Valet power mode issue
JDHudsn
Anyone else seeing issues with their MPH I use the corrected Speedo feature for the quad to get my MPH. And the latest update I will go from 62mph to 67 it never reads in between. Also I use the valet mode to theft purposes and I accidentally started driving with it in valet power mode 1% and it doesn’t cut out like it use to. It use to almost stall when I would start driving if I forgot to change it.
Just curious if if anyone else has encountered this prob!!!
I had the app crash on me when I put it into lvl 1 once where it reported it was in lvl 1 but really was in stock or level 2. I had to kill the app, and turn off the truck then restart everything in order for it to really put itself in level 1. I chalked it up to stupid tablet problems. (The tablet is stupid about a great many things, not just our app).
I would try disconnected the Adrenaline unit and making sure that the app is totally closed. Then reconnect and see if it works properly again.
On 10/1/2018 at 7:47 AM, Me78569 said:
So you can drive around on lvl 1 just fine?  At 20 , 40, 60 mph?
@Me78569 with the update I did the reduction happens when the truck is moving like 5mph. Before it was immediately when I hit the throttle. The high idle also now kicks off as soon as the truck starts moving before the update it would high idle till I hit the throttle. For instance I would coast downhill and it would stay in high idle. Now as soon as the truck moves the high idle shuts off.
@Quadzilla Power Ok sounds good. I will also flash the chip again maybe I did an old flash!
Edited by JDHudsn
