ATF Oil Change. Service Manual Capacity Incorrect?
Today I dropped the transmission pan on my 1998.5 24V Cummins 2500, automatic transmission. I read the manual first to review the task.I bought the oil amount they recommended, at 4 quarts. I reinstalled the pan and put 4 quarts back in so far. ATF is just barely reading on the low end of the dipstick.
2 different places in the manual say 2 different capacities, for the same tranny model. As seen below here.
I just dropped the pan to install a new gasket that was leaking. Looking in my drain tub, there is a lot more than 4 quarts that came out. I am headed back to the store to by more oil. Looking at the drain tub, I'd guess about 7-8 quarts drained out. Any ideas on what my tranny will have required by the time the level is right?
I am testing the level correctly as instructed in the manual. I am not too concerned about overfilling it. As I mentioned, a heck of a lot more than 4 quarts came out. Thanks.
2YSjCvB2qhSo6K79p8vWkKANb2lHopRaXTwErxYi    EPUQh7_0dv1kMtSvI8tCvyA1y2JfCbC3gtTq-ODa
Edited by keithb7
As far as I know it's a stock pan. I just bought the truck in August. Maybe there is a deeper pan for extra cooling? Heavy tow option from the factory? I did see what appeared to be factory Mopar part number stamped in it. I did not record it. The pan looks about as rusted and worn as the rest of the truck on the bottom side. Not exactly accurate, but generally looks in line age-wise.
Edited by keithb7
I just got back from the store. Took the only 3 remaining quarts they had left. My tranny took 'em all. So just a tad under 7 quarts in total and now it's finally reading full on the dipstick. And, no I did not drain my torque converter.
Interesting, my 98 factory service manual seems incorrect.
My 47RE took 19 qts from completely empty just rebuilt. Thats with a deep pan I think 3 extra qts? Its a HOWE i think. He's right though, even in chrysler to this day it claims a 4 qt service and i've never seen one take less than 5/6 quarts for a service with a standard pan. They must've been thinking that they dont give it time to drain?
43 minutes ago, IBMobile said:
I did a trans service last month.   I let it sit over night then sucked the trans fluid up through the dip stick tube then dropped the stock pan, more fluid came out.   I then did the band adjustments, replaced the filter and refiled it with 7.5 qt.
Thats more like it
