- Replies 14
- Views 2k
Bcoan55 6 posts
Mopar1973Man 4 posts
Stormin08 2 posts
Dieselfuture 1 post
Popular Days
I did some cutting, drilling and reshaping and was able to make mine work. I am going to try and do an article this weekend on how I made it work. So far so good. Truck shows it charging when engine i
I need some help, I have a 2001 dodge 24v and I bought the Denso diode pack from the site store to replace the diode in mine. I knew I had a Denso so I bought it. However, I didn't know there were different models. Can I just modify my alternator body to fit the new diode pack? All the holes line up except where the lead comes out of the alternator. Or is there something possibly different between the 2 diode packs? The only real difference
is where the lead comes out. The original it comes out of the side. Where the new one comes out of the back.
here you can see the new one on top with the lead pointing up and the bottom is the old one where the lead sticks out the side.
you can see where the lead sticks out it has a bracket on either side.
The new one the lead sits on top of that bracket. Could I just cut the tab off the bracket so the lead sits flush and cut a hole in the cover and put it all back together?
Thanks in advance.
