- Replies 10
- Views 1.8k
Mopar1973Man 4 posts
dripley 2 posts
IBMobile 1 post
Ravewolf 1 post
Popular Days
Actually, the fuel leaving the back of the head with 190*F thermostat will heat the fuel to near coolant temperatures. Like most will tell you and me. Keep your fuel tank above 1/2 tank and temperatur
Well I do a lot of road time, like you Mike, But I use my full 35 gallons while driving. No half tank fill ups for me. I do not monitor fuel temp, have no way to. But some of my trips would require 3
Since the Quadzilla shows the fuel temperature inside the VP44. I've never been over 140*F even after heat soak. The whole heat thing for the VP44 is nothing but scare tactics. Heat failures are extre
I work in the oilfield, and was helping one of the mechanics fix one of our coil tubing wet kits, namely the hydraulics cooler and fan. It got me thinking about transmission coolers, which led me to think about using one for a fuel cooler, fan and all. Would it be a waste?
I also read about FedEx(I think) had problems with their fleet trucks breaking down because of their vp pumps, so they used heat sinks and apparently the problems dropped dramatically. Anyone hear about this?
Just thinking too much again about how I can prolong the life of my pump, different ideas, etc.
