- Replies 9
- Views 3.2k
Dynamic 3 posts
pepsi71ocean 2 posts
Me78569 1 post
kzimmer 1 post
You need to find out if there are any codes in the PCM causing it to default to max governor pressure. You could also have a power issue to the transmission.
Codes will set (and thus 2nd or 3rd gear starts) when too much pressure is seen by the PCM on the governor circuit. You can have high line pressure, as long as you keep it out of the governor circuit.
Hey guys I have a 99 Ram 1500 with a 98 24V and 47RE. I did not perform all the swap. Problem is trans wants to start out in 2nd? gear in D. Sometimes you get first manually. It has 3rd. OD?. A lot of info pointed me to the governor solenoid and transducer. I changed them, still the same. I was told ecm was swapped and repinned. Where can I find some solid info on diag procedures? I've looked into a full manual valve body ,800$, and tried finding a standalone controller,1400$! Looking for advice. Thank you
