13 hours ago, Thebeastxj00 said:
How do I turn on the high idle on my quadzilla adrenaline v2 with control pod
Set the warmup mode temperature. Like I've got 170*F for this setting. Then you need to set the high idle delay time which I've got 15-second delay.
Warning don't run the Quadzilla high idle with the factory high idle on the ECM  enabled. If for chance the 3 CYL mode is kicked in while the Quadzilla running 6 CYL it will create a heck of a problem.
he only had the control pod, he does not have the iquad so he can't custom tune or setup custom values for things like high idle.
  • Current Donation Goals
    • Raised $20
