wiring up overhead console radio shack switches
I wish I could help because I thought I would have to do this one day and bought the radio shack swithches. When it did happen I found all I had to do was glue the oe switches back together. That was a year and a half ago and the oe's are still going strong.
Much easier...
https://www.ebay.com/itm/99-02-Dodge-Ram-Overhead-Console-Map-Light-Wiring-w-Switches-MOPAR-OEM-5013609AA/333030904466?fits=Make%3ADodge&epid=1717868005&hash=item4d8a305292:g:EugAAOSwlkpcSHD~
Look like white to the center contact and the other two go to the outside contact. So no matter what the light bulb has contact to either the yellow in one position and then black in the other position. So yellow being the door pin ground or black being force ground. The pink is the +12V.
While that is out change the stock bulbs for LED's less heat up there for the switch and everything.
