Looking for Staff Members
I'm building two 47RH transmissions and I need converters for them. But, I don't know which brand of converter to go with.
Has anyone had experience with or know anyone who has had experience with PATC transmission converters?  https://transmissioncenter.net/shop/8dxx-with-steel-stator-option/
They have a buy one, get one for half off special they have been running.
 A triple disc, billet cover, aluminum stator would be $1,000 each. Or I could go with Goerend for $1,050. Ultimate transmission has a triple disc for $1,200. A local small business by the name of Torque Converter Works also has a triple for $1,200. Torque converter Works uses a Sonnax stator, piston and cover.
So, is Patc any good, or should I go with another Converter builder?
Thank you for your time.
  • Replies 10
  • Views 3.2k
  • Hey, you don't have to constantly flaunt it or I'll ban you from automatic trans threads  ...... And then there be hardly anything to read with your coffee
  • @Dynamic would know. Me, I know nothing about torque convertors other than my 6 speed dont need one.
I have no experience with PATC whatsoever. I use either DPC or Goerend converters. They are the best on the market, in my opinion.
  • 3 months later...
How many are on market. Or is there just a couple and they're all branded by everyone and they're brother
There are a TON of converter builders out there. Most use the same internal parts (usually Sonnax) and front covers. Only a few build their own stators, covers and apply pistons.
Hey, you don't have to constantly flaunt it :punish:or I'll ban you from automatic trans threads :thumb1: ...... And then there be hardly anything to read with your coffee :tongue:
I spent 14.5 months working around DC and now I am in Atlanta. Traffic here and there slows to the point you cant idle in first gear without over taking folks. On top of that the drive home thru SC has about 60 miles of road construction. My left leg is taking a beating with that crap. Those days an auto would be a blessing.
Told the wife I would buy a new one if she would drive it. She says "I ain't driving a stick." I told her it would be auto in a new one. She seemed a bit better on that smiled a bit. Sure was tempting at that moment.
  On 8/28/2019 at 3:20 AM, IBMobile said:
Thats the one.
Dripley, so do you say your current job is in 'Big Drumstick' instead of Atlanta?
Edited by JAG1
