Is there a way to tell which Denso diode I need... by looking at the alt is still hooked up?
Like maybe that threaded bolt coming out is in different spot?
Edited by 015point9
Add pic's
  • Replies 14
  • Views 1.4k
  • Dieselinmyblood
    Dieselinmyblood
    I honestly don’t have any experience with these specific products but the vertical or horizontal lead should be fairly obvious. Do you have a picture of your current alternator? I have a 99 and if I r
  • IBMobile
    IBMobile
    This may help show the difference.
  • The larger cable on your pic appears to be coming out the side not the back.   So I think the bottom pic you posted with the all flat module is what you would need.
I honestly don’t have any experience with these specific products but the vertical or horizontal lead should be fairly obvious. Do you have a picture of your current alternator? I have a 99 and if I remember correctly mine comes out the back . Horizontal or your first picture.
Thanks for responding...Will take pic of my alt tomarrow.
Edited by 015point9
That's the difference, on will come out of back and one from side. Just see where your stud comes out.
thats right....in I rder one from larry b...got the 90 degree exit on the bench
mine is straight and i cannot locate one anywhere.
a member did modify the rear cover and used the 90 outlet with no issues yet.
Either the charge stud comes out the side or out the back.
Trying again... poor phone service at my end today. Hope pic uploads before phone "times out"
By pic, which diode do I need?20190606_123722.jpg.061308243bad3f0f0344712214f6b8fb.jpg
You have a side mount B+ terminal and need this type of diode pack.
2014296212_20190315_133736.jpg.1b199db3f1f14e31ddcb4dee30e34865.jpg.17db38ea69c032382aafbc4bf561ea861.jpg.591dbaeee7b06b426bce5e883d899a50.jpg
A rear B+ terminal alternator looks like this,
with this type of diode pack.
1951165503_diodes.JPG.75934d4fd5a872402af434fba55402df.JPG.611faeb759b4c92612c351520e341e041.jpg.ec4373f8457f2c6c8076433a01cf56d6.jpg
Yup hes got his diode pack.
Who is "he"?  I thought you was "he".
I'm going to hold off ordering till you get back back on your feet.
Follow Dr's orders, enjoy the nurses. Hopefully hosp food is good or at least OK.
Did This Forum Post Help You?
