A/C keeps blowing Reciever/dryer off
A/C blows the receiver/dryer off the evaporator connection, I thought at first it was building to mush high side pressure due to fan clutch seized and condenser beat up not getting good air flow, but those have been replaced. Just went to start truck after it sat for 20-30 minutes and it blew again, when it's working air blows ice cold. Was going to put gauges on while not running to see if pressure equalized between high/low sides but that will have to wait.
18 minutes ago, IBMobile said:
Need to have the pressure readings to see what's going on.  Also, there is a high pressure switch which opens between 450-490psi and closes 270-330psi.
Just now, Blueox01 said:
Seems like awful high pressure , mine at running was about 150/45 at 79 degrees ambient temp.
13 minutes ago, dripley said:
Do you still have the clips that hold the lines together?
Yes, but the lip for the spring to latch around has been flattened out, have the dash out now to replace the evaporator, had dash out 10 days ago to replace the heater core, so I got the procedure down.
Those pressures are for the over pressure safety switch not the running pressure.
That falls in the normal range. I think @dripley and you are on to something with that connection and spring.
I've got a whole bag full of the locking springs for that purpose. Typically you can buy a o-ring kit for like $7 dollars and usually have a few locking springs in the kit. Double check the fittings too. Female side without the lock should have a good curled lip for the spring to grab.
Yea, missed that until now, it's been clicking on(could hear spring click) but the lip has been flattened out. I think it's just been connected/disconnected too many times.
