ECM Interchange
Currently having issues with my ECM. My ECM is a 3947912.
Running a spare from an 01 Ram 2500 Auto with p/n 3946242. Works but no oil pressure gauge.
I just came across an ecm from an 01 Ram 2500 H.O. manual with p/n 3947912, same as mine.
I always thought as long as the id number was the same everything was good. But will a manual ecm be fine on an auto?
Edited by gipperkid
If you can buy or get ahold of a Smarty so3 , and call the guys at Smarty they can send you , e-mail the files for any year - model , I think they do charge for them now .
From your computer you load the files into the so3 using an ethernet cable , then into the truck via the obd port  . All ecms work all trucks , but newer years are better for older trucks.
Once you have the file available for your year on your computer , it costs you little to try all the ecms you can get .
ACS said my truck had a short too ,could be ac rip from alternator , or just their "excuse"
They do have to disclaimer the fact that all issues w/truck need to be addressed before installing a remanded ecm , but it leaves you with a lot of work or an uneasy feeling when like you say when their work could have failed
They say they test the ecm after they repair , I`d like to know how after repair I got mine back and it was the exact same as when I sent it to them , I believe they did the repair as it had silicone sealing it , but I don't think they "tested" it
Yours they say  the flash file chip was replaced, mine they didn't and I think that might be the issue with mine , for the money I think they have a policy that only so much work is done before they claim unrepairable or your truck is the issue , I get work for dollar , but they should just be more up front about it
My brother and I swapped ECMs troubleshooting his VP issue.  (our trucks are very similar in year model, both '01.5,  but are otherwise completely different.  his is a top of the line 2wd automatic, mine is a base model 4wd manual.)
Mine is a 5speed and his Auto.  The only thing I noticed during the swap, the Auto ECM does not have the same stall prevention programming that my manual has.   So my 5 speed ECM in his Auto truck made no difference.  His Auto ECM in my 5 speed prevented me from selecting a gear and letting out the clutch and the stall prevention didn't try to maintain idle speed.
HTH
Hag
The cruise control would make difference I would think, the late 01's and 02"s are fly by wire and not mechanical like the earlier years.
Seems some folks have issues while others dont.:shrug:
Edited by dripley
