I finally got around to finishing my on board air system. I now have 3 5 gallon tanks and 3 Viair compressors. 2 tanks are supposed to be from some kind dump truck other is ebay. 1 compressor is a 380c and 2 are 444c, all rated at 200psi max. My pressure switch shuts off at 150psi. I can once again run air tools from the truck. Theres also a horn behind the front bumper that really comes in handy around here.20190913_174555.jpg.39c47825b500489b360d9d3ac076cf6d.jpg
Edited by Gregturley
  • Replies 24
  • Views 5.3k
  • Greg, For the racing trailer I use a nitrogen bottle.  Dude that will save your life.   its easier and cheaper than sketchy cords and low voltage on a compressor, or trying to run tanks back and
  • Nitrogen is nice. My setup works great for me im happy with it. Did a water pump on a friends service truck 7.3l f350. Used air chisel for fan clutch, 1/4 & 3/8 air ratchet for clamps and bolts, a
  • Ill get some tomorrow. It was kind of dark for pics today. The 380c is mounted on the driver side of the skid plate for the transfer case. The 2 444c compressors are on a bracket i made that goes betw
Don't a lot of the ISB's have rear accessory drives? I wonder if those would work on our application.
 The old York compressors found in some Ford applications back in the 70's were the best being you could modify the pump to not pump oil out in the discharge.
That's what I used for years in my Ford dually when it was a gasser. The Cummins is gear drive, Holset 8.5 cfm air cooled. When I need portable air I have one of these.
https://www.northerntool.com/shop/tools/product_200660640_200660640
On 9/19/2019 at 3:36 PM, Mopar1973Man said:
Remember the Cummins ISB was used in many medium duty trucks with air brakes and there is a optional gear driven compressor for these applications.
5.9L Cummins ISB compresor... Gear driven...
Cummins B Series Engine Air Compressor 9111545000X (554-10205)
6.7L Ram gear driven air compressor.
5266299_left_1024x1024.png?v=1562334443
Belt driven air compressor.
Image result for 5.9 cummins engine driven air compressor
In which location does that go into Mike? I'm thinking maybe the PS pump set up?
  • 5 weeks later...
Bumping. This is an interesting topic
