Quadzilla adrenaline gauges problems
Eglfan22
Has anybody had this problem my quadzilla adrenaline shows 5-6 boost psi at idle and when i plugged in the fuel pressure sensor it only reads 3psi all the time but my regular pillar gauges read jist fine so whats going on with the quadzilla adrenaline i just bought it everything else works fine on it
27 minutes ago, Mopar1973Man said:
What year of truck? There is a jumper inside the Quad to select the early or late series MAP sensor.
Its 1999 with ard 1000 box i read that on quadzilla website that wouldn't have anything to do with the fuel pressure gauge not working ?
1 other thing i noticed it never did this with my comp box the smoke is grey coming out of the exhaust if i switch it back to my comp box its jet black smoke. Im tried stock tune on level 10, the street tune for 7x10 injectors from you
