Engine Control fuse keeps blowing
Gen light came on a few days ago so I pulled my alternator and it tested bad.  I replaced it with a cheap reman and it still wasn't charging.  Today I notice that the 30A engine control fuse was blown so I replaced that and started the truck.  Bingo!  Everything was charging as it should.  I took the truck for a victory lap around the neighborhood and the fuse blew again.  Popped another fuse it to see if it was a fluke and it popped too.
Recently I have installed HID headlights, but don't believe those are the problem because everything worked fine for a week or so... on the same day as the headlights, I also installed a new bumper.  There were a couple of ground cables connected to the old bumper bracket that I moved to a spot on the body (new bumper didn't have a good location).
I figure I am dealing with a short somewhere or a bad PCM?
Any thoughts?  Thanks in advance!
Thanks!  If I am reading it correctly, it looks like the only thing that it affects is the PCM/ECM which regulates voltage to the alternator... and that's pretty much it on the 12v (on a 5 speed anyway).
This confirms my initial assessment.  If I install an external voltage regulator, it should remedy the issue, correct?
Thank you for all the replies.  I am still chasing down this issue but will definitely update when it is resolved.
wil440, you are correct, I need to find a better location to ground than the body.  I will try that out.  Aside from that, I have all new battery cables and connectors to put on sometime this week (the old ones are stock and in pretty poor condition).  I am hoping that one of these will do the trick.
I tried a different ASD relay and that didn't make any difference.
