Old girl got a quad and other goodies
Big night last night for Big Brown. She got a quadzilla with stealth cover,  tranny flush with amsoil, replaced my leaky cracked oem wheels with a set of 17” 4th gen wheels that came with good used hankcooks for $150!
I did hit a couple snags though. Anyone ever seen where a BD boost elbow is too large diameter and won’t thread into the turbo? Also for most of Me78569 how much fueling should I add for 3500 ft? I took the truck for a spin at 1am and didn’t have quite the punch I was expecting from a few of the tunes.
PS ignore the mess, I just moved in and still organizing things and doing some renovations
What would cause a dead pedal feeling? I’ve got balls to the walls loaded and seems like after quarter throttle nothing changes. My apps is showing full 100% position when I floor it though
There’s a definitive drop off where the rpm rate it increasing and then drops off and it plots along
Also getting a max of 3psi, checked all connections and looks like I don’t have any leaks and I should hear one that big?
I had an issue with my boost elbow not fitting.  Returned it and got another from XDP and it wouldnt fit either.  I got my tap and die set and made it fit. :whistle:
I emailed XDP and told them to check their stock, that I think they had some elbows incorrectly marked but I never really heard back other than the obligatory "thanks for your email" email...
11 minutes ago, Me78569 said:
What level do you have the quad on?
If you are running lvl 1 of the tune it will do exactly what you are saying.
Lvl 1is valet mode.
Sorry if this is a stupid question but are there multiple levels on a custom tune?
On 1/5/2020 at 8:01 AM, hdpwipmonkey said:
Yes.  Even custom tunes have different levels.
They all follow the same format:
Lvl 0 = Stock
Lvl 1 = Valet (set to some decreased power)
Lvl 2 = Timing only
Lvl3 = Timing and Canbus fueling
Lvl4 and up is wiretap fueling
Small correction.
Lvl 2 = Canbus fuel only to 100% and timing.
