No Communication between ECM & Injection Pump Module
- Replies 5
- Views 4.8k
dripley 2 posts
Royal Squire 1 post
wil440 1 post
Eviltwisted1 1 post
I have checked all the fuel pressure. I have checked all wiring ( no cracks splits broken). APPS sensor has been tested recalibrated & set.to ecm .
Non of this has worked or helped Anyone to be able to Help Me!?
So I really need help. Stock motor 89 5.924v
Code P1689 still learning Deisels myself . Checked as much is as I can. But basically its No Communication
between ECM &Injectio Pump Module
So what part is it that is Bad?
Is it the ECM or something else.
I'm desperately trying to get this figured out. Unlike all other guys that have this issue. Mine doesnt spit sputter, burp pop. Nothing.
I cant even drive it.
As.i only get idle or Any throttle At ALL it instantly jumps to 1500rpms. Nothing between after tou give it any throttle at all no turbo trying to kick in, . Motor sounds & idles perfectly. Like it should run fantastic, but I cant for life of me figure it out or find the answer for sure .
And I dang sure cant afford dealership like most of us on a budget. Any help I'd appreciate for sure.
Or if anyone knows of good shop near ft myers.fl who wont rape.me. please.let me know
