- Replies 7
- Views 1.6k
dripley 3 posts
LorenS 2 posts
Dieselfuture 1 post
Doubletrouble 1 post
Popular Days
You could very possibly have two issues, failing thermal coupler I had that happen, and the weak fuel pump or something going on with it. This is definitely the case of forewarning of doom by pa
You might check and see if you have any trouble codes. The truck might be giving you a hint. As far the fuel pressure dropping quick after the prime, if you have needle valve on it just close it
Over the last week I've noticed some strange behaviors from my truck and want you all's opinion on whether I'm being paranoid, I just need some maintenance, I'm about to have a serious truck breakdown to deal with, or something else altogether.
Background: I'm in Minnesota, and my fuel tank is full of local "Premium" diesel. Temps are ranging from the 20s to even a few days in the 60s. Fuel from the same station I've used a lot in the past, newer station, sells lots of diesel. Other guys I work with fuel here, too, no problems. I'm running my Quad on Level 2 for MPG, as I have for a few thousand miles. Fuel pressure is unchanged. Can hardly tell about MPG changes as sometimes I fight a 40 MPH headwind on the interstate, and by the return trip don't get the benefit of a corresponding tail wind. Also, except for 100 mile round trips to a "neighboring" town, most of my driving is just putting across town to the local pork plant and back to the hotel. I've been keeping over 1/2 tank of fuel.
Symptoms: I have had my "Turbo Timer" set for 300 degrees and until this week (after getting fuel the last time) the engine would run maybe 10 seconds after shutoff, even when 60 degrees out. The past few days despite it being in the 30s to 40s my truck would run for well over a minute before finally shutting off. I have since bumped the shutoff temp to 325 so it actually shuts off before I make it into the hotel from across the parking lot. This is even with a coolant temp of maybe 150 degrees (drove to hotel for lunch from the plant, which is just a couple miles of flat ground).
My EGTs had seemed to be higher than normal despite same route, driving style, tire air pressure, etc. I have not noticed any excessive smoke, and boost pressure seems same as always, though I admit I don't usually pay a lot of attention to that.
I thought maybe the thermocouple was just going bad until I had some rough starts the last two mornings, and even sputtered some at lunch today. This morning it hardly wanted to start, acting like it had an abundance of air in the fuel system, belching unburned fuel and running like crap. Once it ran for 10 seconds, it seemed normal, leading me to believe it's not a fuel gelling issue. Used to be when I flipped the key to Run to let the grid heater do its thing the fuel pump would run its couple of seconds, the pressure would come up a little and SLOWLY bleed to zero if I sat there long enough. Now, the pump still does its ~2 seconds of prime and the pressure just falls to zero FAST - actually, as I type this I'm not 100% certain the pressure comes up much, but I do here the pump run, and like I said above the fuel pressure is otherwise same as always. There is not a puddle of fuel under the truck, though I swear I have had a small leak from near the VP44 dripping down the front of the engine; however, I can never find it!
Air in fuel causes delayed ignition, does it therefore also contribute to higher EGTs? Is this just a simple case of needing some fuel plumbing maintenance, or...? Not sure if if it's in my signature, but I run a stock "formerly engine mounted" pump, relocated to near the fuel tank, draw straw, 3/8" Parker fuel hose, stock filter housing, no banjos on the supply side.
Would love to read your thoughts on the matter, thank you in advance. I will not likely be able to read or respond until tomorrow (Tuesday) evening.
