It appears you can replace it to me. Whether or not you have to pull the cam I dont know. The crank tone wheel can be pulled since it is 2 pieces. Maybe the o e on the cam is too. There is a possibillity the cam sensor you installed is bad. It does happen occasionally.
Here is picture of my gear and you can see the fasteners that hold it on. Appears to be 3 of them screwed in from the back of the gear.
9 hours ago, Mgarner96 said:
It’s just so weird to me that on my edge cts2 monitor it monitors engine speed and while I have a dead tach on the ic, the one on my monitor reads just fine
Exact same thing on my donor ecm, I bet it's in ecm or wiring/pins. Be nice if you had another one to try
