Doing the WT ground mod
As long as the relays stay in place, and you just unhook the main power lead, you will not show an error in the PCM.
The computer is kinda stupid.  It only checks that there is resistance in the control circuit.  (that is how it knows there are relays there to be cycled.) It does not CONFIRM that power flows from the battery to the grid heaters.
So basically, if you leave the relays in place, the computer thinks everything is kosher.  It doesn't know you have it relaying nothing.....
Hag
