Need help
My 99 has been starting and shutting off and I’ve  replaced and check everything it’s there something else or any tips to help me with this headache
  • Replies 4
  • Views 1.2k
  • Doubletrouble
    Doubletrouble
    Apparently he got it figured out. Hasn't responded in 16 hours. Lol
 Probably going to need more info on this. What have you tested so far?
 Truck is a '99, so far that's all we know. Auto, manual, milage, mods or all stock and so on. There are so many different combos both stock and aftermarket. The guys here will help you though the best they can but they also need all the information you can give them to help make an online diagnosis.
I'd check cable terminals below drivers battery and all other cables first.
Also check for trouble codes. They are helpful even if they dont point to something specific. Not all codes set the CEL either. Then again not all problems set a trouble code.
