- Replies 14
- Views 2.5k
Mopar1973Man 5 posts
AH64ID 5 posts
Rogan 4 posts
That’s only big on size, not on flow. That’s pretty dismal on flow, as most BHAF’s are. An HX35 can flow nearly 600 CFM, and a HE351(5.9 and 6.7 OEM turbo) is over 800CFM.
I would look for a used OEM air box, it may not be that hard to find. I'd even go the sealed S&B route over a BHAF. The underhood temps are much higher than you want to i
When @Taz gets up here I'll verify his truck he's also got a BHAF but I don't think the temps are as high as you think. I can jack into a the OBDII and check the live data.
Hey, guys. I picked up an 07.5 dually. I'm in need of a few items, so thought I'd pop it up here, too.
I need 2 17" dually wheels (steel), and an air filter assembly (they were missing when I got the truck)..
IIRC, @MnTom ran a BHAF on 3gen truck.. Can this also be an option for the 6.7L? Anyone got info or pics on this? THanks..
Also, if you know of some dually wheels laying around, LMK. Like I said, I need 2. I can't seem to find any on CL or forums (chevy or dodge.. i find a ton of ford crap.)
