Rough Idle & Bucking After Installing Head Studs, Turbo and Injectors
- Replies 10
- Views 2.9k
Mopar1973Man 3 posts
Dieselfuture 3 posts
FCAWdude 3 posts
LorenS 1 post
Well this looks good. Does it still idle rough or you only have bucking issues when driving down the road. I would do wt mod next before I do anything else. It might surprise you on the outcome.
Thanks for responding. Engine load at idle = 11% +/- 2% RPM at idle = 800 +/- 5 TPS input at idle = 0 Haven't done the WT mod, but it is on the list of priorities
Yup he's got you on the right direction so far. You do realized after just about 20k to 30k miles those injectors might drop pop pressure again and be below minimum pop? Dodge FS
New to the site here, and I've combed through hours of posts, but wasn't able to find any thread that exactly described what I'm experiencing. I also tried everything suggested in the posts below but still haven't been able to resolve the issues.
@Me78569 75hp Tow Tune
No improvement with bucking
Added %5 to 0 psi 4% to 1 psi 3 % to 2 psi and so forth per Me78569’s suggestion from this post
Seemed to help the bucking issue a little bit, but still obviously there
Completely Unplugged Quadzilla
Bucking improved, but still there at 40-50 mph, 1200 rpm, light throttle, 4th gear overdrive locked.
Hooked up scan tool, no codes being thrown
Still in the process of learning the ins and outs of the Quadzilla tuning, but I can't help but wonder if the issue is mechanical. . . . Any and all troubleshooting ideas welcome, getting desperate
Edited by FCAWdude
