2002 Cummins - Weird issues
- Replies 5
- Views 1.6k
Mopar1973Man 2 posts
dripley 1 post
ddmk6 1 post
Threadzy 1 post
Yesterday I had a client call me and told me he was coming. Ok he drops his rig off here and I had to run back to town any ways so I dropped him back off and chased the two Fords in Riggins. Get down with my jobs and head into town to just double check before I head home and the CEL comes on.
I got two codes off the odometer but my OBDII tool showed nothing, no readable errors even though the CEL is ON. P12xx code and P13xx code. Never bother to write them down. After just hooking up and hitting erase they are gone and never came back. I figured if they are true code they would return. Nope gone and never came back all day. Even my trip to McCall no issues.
The problem I'm worried about is my volt gauge randomly with chime the CHECK GAGE light and then watch the volt gauge drop to ZERO. Now looking at my USB plug voltage it shows 14.3 Volts. Then I stopped in Crump Chevron and check again too same result the batteries both have 14.3 volts too. Why is the volt gauge dropping out? From what I know the volt gauge comes from the PCM. I'm going to double check wiring and plugs for salt water entry. My entire truck is covered in salt right now. Been too cold to think of washing it.
I need to do axle fluids and change transfer case fluids too.
