Full Send Diesel Temp control trans pan
I was casually looking for a transmission line kit and came across this fancy transmission pan.  It allows you to bypass the heat exchanger, it has fittings in the pan to run engine coolant.  It looks like it could eliminate the possibility of making a large milk shake should the factory exchanger fail.  It's not cheap but it has me rubbing my chin and going Hmmmm.
Edited by Sycostang67
I would think that in the summer that the 190-210⁰ coolant would be cooling the transmission fluid, but I guess I've not paid much attention to it. And if your coolant is warmer than that, I bet the transmission is HOT, too. Not sure I'd bother with shutoff valves.
When mine goes, I will likely try something like this. I was searching for a small shell and tube heat exchanger, and this popped up. Much more economical.
https://www.mrcool.us/63832t-mercruiser-engine-oil-cooler.html?gclid=CjwKCAiAwc-dBhA7EiwAxPRylIWuvnw3DGZiyGn15wpnydogyaNnQ4DYegcLRayE8icVje6GVuhQyBoC_J8QAvD_BwE
