P1693 to pdone to coughing and puff of black smoke then white when warm...
- Replies 10
- Views 4k
rockcrawler69 4 posts
Mopar1973Man 3 posts
jlwelding 1 post
BlackRam2500 1 post
Well, I was going to take my truck in today to have the codes read because I had the p1693 companion code. To review, I started another thread about my truck choking out on the highway, where I could power through it or back off and it would go away. Then my batteries died and after installing the new ones the truck seemed to run great! Now to my new issue... Towed my rock truck to an event this weekend and the truck only "choked" a little on the way up. Coming back I had to drag my buddies trailer back. 40 foot gooseneck with two buggies on it. I'm guessing 16,000 pounds. Truck was running great, went to lay into the throttle going up a hill and holy cow I thought my truck was going to shake itself in half and break apart. Same symptons as before, I could power through it or lay off the throttle and it would go away. This happened in OD and out of OD. So I took it easy the rest of the way home because everytime I would get into the throttle this shaking, choking, thing would happen. Well, made it back to town and after unhooking decided to do the key trick. I got a pdone no more p1693. ( maybe my new batteries had something to do with this.) I fired up the truck and then stomped the pedal, in park, to hear my exhaust bounce of my buddies concrete wall.
about 1500 RPMS it went pah, pah, choke, stutter, vroom.
Sorry no other way to explain it. Did it a couple of more times and the same thing happened. I also noticed when this happened I would get a puff of black smoke followed by white smoke. If I steadily pressed the accelerator pedal it wouldn't miss a beat and rev all the way to 3K with no issues. But, as soon as I stomped it hard it would choke and do all the other stuff as it was in the 1500rpm range. I started the truck this morning and tried to repeat the problem and coudn't get it to repeat the problem. Got to work and tried it after the truck warmed up and the symptoms were there again, stomp the pedal, choking, cough, pah pah, vrroom, black smoke then white smoke and still showing a pdone code. Help!!!! Sorry for the long post but don't know how else to describe it. So what do you think is happening or worst yet happened?
