I'm looking to get another head for my 01 HO just so I can have it already to go when I change my head gasket don't want any issues when I get into it now I found a head with low miles sounds like a pretty good deal the only thing is that it's from a 98 24v now will this work on my HO??? Thanks
  • Replies 9
  • Views 2k
You going to have a head shop see if it needs to be shaved, pressure tested and checked for cracks?
had to plug in laptop..battery went dead:lmao:that would be the wise thing to do..have it looked over good before installing.so you wont be :doh::duh::evilgrin: later on.
Yes it is leaking a little bit at the right front cornner. I found a head off of a 98 with low miles approx 26000 was thinking that it might be in pretty good shape as the engine it was on lost a cylinder.
Has your head ever been off? Do you suspect a problem with your head? How many miles on your engine? Has your engine ever got really hot?
whats it cost to get head work done eg head offmachinednew gaskettinstalled and (if existing head gaskett issue) head offmachinedO-RINGEDcleaned (radiator and other leaks etc from blown head gask) new gaskettinstalled :shrug:
whats it cost to get head work done eg head off machined new gaskett installed and (if existing head gaskett issue) head off machined O-RINGED cleaned (radiator and other leaks etc from blown head gask) new gaskett installed :shrug:
If it's leaking were i think it is,the corner where the thermostat sits it probly has'nt lost a cylinder seal. thats where mine was leaking,just checked head for warpage new OEM gasket and done.:2cents:
Do you need to get the truck back up super quickly or are you a pessimist? (Or do you have reason to suspect a serious problem the will require head replacement anyway? It just seems that cleaning the head up & putting it back would be much cheaper. If the head fits, as the others have stated, that's fine... You end up with a spare head to store or resell...Russ
