Stock... You not really putting out much for HP to require a larger clutch. The stock clutch is good to ~350 HP at the flywheel. But a Southbend Con OFE is a nice small upgrade to ~450 HP at the flywheel hold.
that is what im running and i like it so far. i would recommend using the updated heavy duty slave clyinder and master i think it would be a little nicer to mash on than the stocker that im using!!!
