when you install the 2 " levelling kit are you better to go with longer shocks,do you need to go with special rims so your tires don't rub against the frame?:cookoo:
I retained stock shocks as well. No issues at all. Stock wheels as well.
Yeah a 2 inch leveling kit makes the front sit higher than the back, I installed the 2 in leveling spacers on my 05 ONLY because I installed a ranch hand bumper and it sagged the front down about 1/2 inch overall and with the 2 inch spacers raised it to 1/2 inch higher than stock which makes it sit level. I think they look dorky sitting higher in the front with nothing but the levelling spacer.:2cents:
My 02 I installed the heavy duty 988AA factory snowplow package springs and with the ranchhand bumper it sits exactly the same height as stock With the stock springs it sagged about 1/2 inch like my o5 did.
so when you want to go with 35" tires they say you need a 2" levelling kit so the tires will have more clearance,this is kind of odd they don't sell you a kit that lift the back end also.Now I need to make something up to lift the back,I sure don't want to drive around with the front higher than the back :rolleyes:
