Ok I know I have the edge juice with attitude and cts! I'm using it to monitor all my gauges! But I'm thinking about putting in a 3 gauge pillar mount, going with 60psi boost, 100psi fuel and egt gauges! What brand do you fellows recommend using? What is the best?
Boost gauge is fine... Fuel pressure you got to use a 0-30 PSI fuel pressure... Because 15 PSI isn't going to move the needle much on a 100 PSI gauge... :duh:EGT's you want a 0-1600*F pyrometer... As for company take a peak at the manufacture listing... http://mopar.mopar1973man.com/cummins/manufacture/manufacture.htm
I'm running Autometer only wish they had the OME Dodge gauges when I bought mine. Sure is going to upset Momma when I replace them! :thumb1:
Posted Image
My question is I want to add a fuel pressure gauge should I dump the boost gauge or add the fuel gauge using a Single
Steering Column Pod?
Here is a link to Diesel Manor they have a ton of install info on their site. http://www.dieselmanor.com/installsheets.asp
