  • Replies 5
Been too busy to take pics! Bed is off for replacement.yada yada yada:rolleyes:Here is where I am at:DONE! :hyper:Raptor 150 is installed with ISSPRO Fuel pressure gage; pump is adjusted to 18 PSI at idle.Glacier Diesel Bigline KitTo DO/InstallNew ECM on the way from MOPAR :stunned:New Bluechip Pump has arrivedNew Bosch Marine Injectors from thedieselstore
New (Used) Bed is installedFuel Pressure is set at 18 PSI (Idle) maintains 16 PSI WOT; it does "blip" 2 psi every 45 seconds or so.New ECM has arrive, will install Thursday, appt to get flashed on Friday
  • Current Donation Goals
    • Raised $20
