- Replies 6
- Views 2.9k
Mopar1973Man 2 posts
MnTom 1 post
kydamcat 1 post
dripley 1 post
I just had the VP44 and the lift pump on my 98.5 Dodge replaced. At idle, the engine surges from 600 to 800 rpm and wants to die when the accelerator is pressed. The injectors have been bled once, the pump has been primed with the key trick once or twice and I am not sure if the APPS reset has been done. A friend is doing the actual work, he is a heavy equipment diesel mechanic and has never worked on a Dodge. I do trust his work mechanically. Am I right in thinking we need to reset the APPS, prime it a half dozen times and bleed it one more time?It's kind of funny, I have been reading on here for several years now and never had a reason to post. My old 92 12V just never broke down and I'm not smart enough to give a competent answer about these 24V's. I've been in deep do... every since my wife decided I needed a better truck and bought this piece of junk without talking to me. I would appreciate any suggestions you have. I do believe we're on the right track.:pray:There are no codes showing now that the pump has been replaced.Russ is probably the only one who remembers Tudor the Turtle.
