Possibly an electrical issue
- Replies 7
- Views 2.7k
ccrider 3 posts
dripley 2 posts
Mopar1973Man 1 post
gassernomore 1 post
Hey guys, was searching around on the internet trying to see if anyone else was having the same issue I am but cant seem to find anyone with the same problem, and anyone I have talked to has no idea at all. I wish I could remember what I did when it all started, what happens is it has a little lope but its not constant, it will idle fine for a second then have a lope in the idle for a second and just keep doing that back and forth. The headlights and dash lights will flicker at the same pace as the lope. I have put an external voltage regulator, a raptor factory replacement lift pump, and a quadzilla adrenaline the one awnser I did get from a guy was that the quadzilla is probally messing up and fueling way to much then normal again, which I am thinking makes sense since the turbo guage is messed up and it will read from 3-10psi and everywhere in between just sitting idle and the fp guage just got fried a while back just wanted to see what you guys thought. I do not see how it could be air in the lines because its not constant it will idle fine for a bit then go back to the weird loppy idle. The more I think about it the more I thinking the quadzilla is garbage,
