- Replies 3
- Views 2.4k
Mopar1973Man 1 post
LiveOak 1 post
Dave3500 1 post
Buddy of mine has a 1999 2500 4x4 (I assume 1999 on the plate on the door says mfg date is 7/99).He was driving his truck working just fine, then it died suddenly at 70, now it will start runs real ruff, barley idles, and there is no response from the throttle (aka dead pedal).The check engine light is on, however the ignition key on/off 3 times does not display codes via the odometer, it does on my 2002 2500.My question does the 1999 display trouble codes via the odometer (digging on the internet some say it should some say it will not)?2nd any ideas / hints might be wrong with the truck ?I know codes are needed otherwise just chasing our tails but thought someone might have some initial thoughts. Truck is not drivable so going to say autozone to pull codes is out. Going to try and pick up a inexpensive code reader.Thanks in advance, Tony
