- Replies 18
- Views 3.7k
Mopar1973Man 8 posts
angus 8 posts
2500ctd 1 post
JAG1 1 post
my sons 99 model died and would not restart, I have traced the problem back to the ECM which is only sending 8.9 volts to the lift pump. I have disconnected the pump and the 50 pin connector on the ECM checked for short circuit and everything is good. I then cleaned and checked the 50 pin connector reassembled and still 8.9 volts coming out of the ECM.I was wondering if anyone has seen this issue before ?
