rear brakes locking up
sorry to be a:postwhore:but my rear brakes have gotten to where they lock up when jus barley applying the brakes it started out just when i was settin and it rained the first time applying them theyd lock up but now i can feel them grabbing all the time:banghead:. i know the shoes arent wore out due to a few months agoe i had a wheel seal and bearings go down:spend:due to prevous owner over tighting the nut:doh: the shoes where cleaned with brake cleaner. has any one else had this issue ?
possibly the proportioning valve is failing or somehow the adjusting wheels are messing up. Try loosening the adjusting wheels inside the brakedrum and let them reset. if it still does it then i would look at the proportioning valve. It is above the axle driver side linked with a rod. when the rear squats down it will turn the valve arm up giving more braking force to the rear wheels. when empty it is the opposite.
We have a 2001 Durango that did that I took it in to a shop after 6 months of trying to fix it and all it was is not using the emergency brake they said the e brake needs to get used because that's what adjusts the rear brake it did fix my proplem don't know if it would be the same way for the truck
I went through this with my '96. (mostly when rain or air was damp). It was a couple of issues, combined.. riding the brakes for the first 5-600ft or so, of initial movement, would usually help dramatically.#1 - Rear seals were leaking a little, and putting grease on the pads. I replaced the seals and pads - Problem got a lot better, but still did it. Usually it was the first brake application of the drive, that was the worst one.#2 - replaced drums - problem went away completely. There was grease imbedded in the pores of the steel drum that I could never seem to get out, even after a severe cleaning of the old drums. They were also slightly out of round.
that's the same one that was the culprit on my '96. just make sure you use brake-clean on the new drum to get all of that crap off of it they use to keep it from rusting..Do you notice it being really touchy the first couple of brake applications then taper off? or does it do it all the time, every time?
i will asap that is when weather gets beter its been warm here right untill i get ready to put some time in my truck and it turns of rainy and cold just my luck:doh: i do know this is the side i had to replace the wheel seal and bearings do to prevous owner over tighting:banghead: and my dad cleaned the drum and pads with brake parts cleaner while i ran all over finding parts:ahhh:as no one place here had them all i had to go to 4 dif places to get them but then when we got it back to geather he tightend the brakes back up cause we had to loosen them to get the drumm off i wonder if he got them to tight is there a way to back the off a lil whit out removing the drum
Oh, if your parking brake works okay, then on your first brake application of the morning, once you leave your driveway, get about 15mph or so, let off the throttle, and slowly apply the parking brake ONLY.. see if it still grabs. If it does still grab, then it's DEFINITELY not a proportioning valve or ABS control issue ( or anything hydraulic-related, for that matter.)
