Fuel Pressure Gauge
3 Questions: 1. I looked at the Pricol Optix 2" Fuel Pressure Gauge (Elec) 0.30 PSI (BLK) on Geno's Website. Is this what I need to safely monitor my fuel pressure? 2. Is there a less expensive gauge that would serve the purpose? 3. I have a test gauge that came with the installation of my Banks P/P. Where do I find the fitting to connect it to check my pressure? ThanksOld Fart Non-MotorHead
  • Replies 5
  • Views 3.8k
Try looking here: http://www.vulcanperformance.com/category-s/131.htm I have never used an electric fuel gauge before so I really cannot comment. I have the ISSPRO fuel pressure gauge routed thought a fuel pressure isolator in to the cab gauge cluster on the A pillar.
3 Questions: 1. I looked at the Pricol Optix 2" Fuel Pressure Gauge (Elec) 0.30 PSI (BLK) on Geno's Website. Is this what I need to safely monitor my fuel pressure? 2. Is there a less expensive gauge that would serve the purpose? 3. I have a test gauge that came with the installation of my Banks P/P. Where do I find the fitting to connect it to check my pressure? Thanks Old Fart Non-MotorHead
If you have a mechanical test gauge that you want to hook up to check your pressure you can use the test port on the side of your VP-44 fuel injection pump. If you don't have anything attatched to it right now it will have a schrader valve on it & it will have a plastic cap over it. VP-44 is on the drivers side of engine up in front of the fuel filter housing.....
Hooked up the pressure gauge and got a 18PSI at idle so I guess my FASS is doing it's job.
Yes...
Mechanical is much cheaper than electric...
Right here if its a banjo bolt... Bottom of the filter housing...
Thanks Moparman. I found the port on the side of the engine forward of the filter housing. I got 18PSI @ idle so I'm guessing my FASS is doing its job. I will go the mechanical route for the gauge. Are they hard to install? Will get a single column mount from Geno's.Thanks Mohok
