starting to get a click from the starter seems to be getting more frequent replace the starter or buy the new solinoid repair kit?
  • Replies 4
  • Views 1.2k
thanks guys for the quick response ordered from larry bs before it goes out all together
its an easy repair, the top nut break loose from the bottom then go in from the top of the engine compartment, take the 2 bolts off the filter housing and push it out the way, full access to the top bolt with a ratchet!!!when installing, put the 2 bottom bolts in first to hold the starter then put the top bolt in, get it just finger tight to seat the starter, then tighten the bottom bolts then the top and put the filter housing back on. DONE! took me about an hour taking my time.:thumbup2:
