Any advice ?
I'm getting a code P0193 fuel rail pressure sensor high. When I take a dvm to the 5v supply to ground I get only 7/10ths of a volt,almost like its a short. I attached the fsm wiring diagram and it looks like the MAP sensor is tied together through the DG/OR wire. So does MAP sensor get its 5v supply on the LB wire then out through the DG\OR wire to the rail pressure sensor? That's the way the picture looks like to me, but this schematic is different then what we use at my work.And why I'm I not actually getting the 5v to my rail pressure sensor, is it because the MAP sensor is out, but I'm not getting any map codes P0106,0107,or 0108 , I'm not getting any of these codes. Any thoughts? post-11820-138698188676_thumb.jpg
