Fuel canisters.
So I've been reading about swapping over to the later 2nd gen "01-02" fuel canister/filter. I am curious just how much better the later model canister flows compared to the original? Will the current filter set up that is on the truck keep my fuel pump from adequately fueling the injection pump? Thanks.
Fair enough. I just picked up a fleet guard filter to change it to. If I do the swap it wont be for a while, but I thought I would check into it also. Oh and a big thanks to you to Dripley as you were the first to reply to me on the cumminsforum when I had my initial VP44 issues.
- - - Updated - - -
