- Replies 8
- Views 2.2k
dripley 2 posts
CUMMINSDIESELPWR 2 posts
Mopar1973Man 1 post
H.R.D 1 post
So gents, i am in need of figuring out which clutch to purchase, mainly power wise. My dilemma is i only have a ballpark of the max my truck puts out but i dont want to be way over or way under and end up purchasing a clutch that is insufficient.I want to get a complete kit, clutch and flywheel as i think the original flywheel is garbage.All i have done is rv275's, bhaf, edge juice w/attitude. everything else stock and will stay that way. (truck has plenty of power.I rarely tow, rarely "get on it", dont pull nor race.I cant get an estimate on power as the current clutch slips with ease in setting 1 now, so im stuck.on the power rating they put on clutches, is that off the engine or to the ground?I figure off the engine im doing ~395hp ~800 torque. would this be a correct guesstimate? to the tires... i dunno...with this i should go with a clutch capable of handling 400hp 800 tqe. I am going with either Valair or South bend.thoughts?also are any of the vendors able to supply a member or veteran discount?
