Power steering/Brake booster issues
I recently had to replace my steering box due to a broken output shaft. Put a upgraded Borgeson steering box on the truck that I got used for a good price. Worked fine on the truck it came off of. Ever since the brake pedal has been really hard to push initially, then when it gets past the hard spot in the pedal, the brakes seem to almost lock up and toss you into the dash. The steering assist is almost non existant at idle. The assist goes away completely when using the brakes. Steering acts completely normal driving down the road but the brake problem is still present. Just installed a new Borgeson power steering pump on to replace the old one per their recommendation. No air in the system, currently waiting on a return e-mail/phone call from Borgeson and thought I would see if anyone else has ran into this issue before.
On the brake part of it is there ABS or BRAKE light lit? Did you purge the system of old fluid before setting all back up? I just wondering if there is debris in the fluid that might of plugged a port or something. As for the brakes its sound like a ABS issue almost.. :shrug:
No, there aren't any lights. Have flushed the system 3 times now not counting cleaning out the system while chnging the steering box. The brakes actually work great, it is more the pedal/booster/master cylinder that feels weird. It is like holding your foot on the brake pedal witht the truck off after you have purged the pressure from the accumulator, then starting the truck.
Fire,The hydro-boost is really pretty easy to rebuild. (if you want I can send you some pictures etc. on the rebuild) I have not done it on the dodge yet, but did it a couple times on the 6.5TD Suburbasaurus. Look for piratejack dot net. They had the best prices on kits, and seem to know them REALLY well. I think a call to them might help you out a bunch.My borgeson box works great, and since yours worked well earlier, I am betting some dirt got into the Hydroboost making the apply non-linear. GL HTHHag
  • 2 months later...
Well, thought I had it figured out. Got the kit from piratejack and rebuilt the booster. While it was apart I found the spool valve was sticking pretty badly. Got it all freed up and put back together and it worked good until the drive to work today. Had the loss of steering and the odd braking again. I'm really thinking it may be the steering box, does anyone know of any options for a steering box other than Borgeson?Sent from my DROID BIONIC using Tapatalk 2
Fire,Glad the build went good for you. Sorry you are still having troubles.I hope someone will chime in, but other than the borgeson, there is only one other box that I can't quite remember the name... I swear it is like redhat or redneck or something like that.LOl it is Red head. Try them. It seems like some have had good success with them.Hag
  • 2 months later...
I just wondering if there is debris in the fluid that might of plugged a port or something. As for the brakes its sound like a ABS issue almost.. :shrug:[/quote
my post from last night.. on our '00 3500 with no power steering and brakes...
Ours DOES have the abs/brake warning lite on. (been on since last pump replacement) 2 years or so.
Dealer said not to sweat it... we don't need abs anyways.. (hows that for commitment?)
After reading this thread... I wonder if I have a stuck valve too?
When mine lost all steering and brake assist it was the relief valve in the pump stuck open. The valve that sticks now keeps the brakes locked up and on these systems the brakes are first priority for assistance so there is nothing left for the steering to use. I think there is a seal blown in my steering gear since it fine turning left but no assist and brake problems turning right.
well, so far everything works fine... right up to the point I REALLY need steering or brakes! ie; the start of a 90* corner... its not very fun to keep the revs up, one foot ready on the brake, and the other on the clutch... and one hand on the door handle for a last second egress... As long as the engine is running above 1500... everything is good.I was just hoping to find a flow chart to diagnose this, and not have to throw a bunch of unnescessary parts at it!doing a little searching and this is a fairly common problem.... ranging from what you said, a stuck valve, blown fuse, (abs lite) debris... etc. ...... one thing I did notice this fall, was the feed line from the pump to the booster was very hot. I always figure a hot line means there is too much flow going through it... a stuck valve allowing too much bypass?
well, so far everything works fine... right up to the point I REALLY need steering or brakes! ie; the start of a 90* corner... its not very fun to keep the revs up, one foot ready on the brake, and the other on the clutch... and one hand on the door handle for a last second egress... As long as the engine is running above 1500... everything is good. I was just hoping to find a flow chart to diagnose this, and not have to throw a bunch of unnescessary parts at it! doing a little searching and this is a fairly common problem.... ranging from what you said, a stuck valve, blown fuse, (abs lite) debris... etc. ...... one thing I did notice this fall, was the feed line from the pump to the booster was very hot. I always figure a hot line means there is too much flow going through it... a stuck valve allowing too much bypass?
Hot line is excessive pressure. Excessive flow would actually keep the line relatively cool. When my brakes apply themselves i can grab the line from the pump to the booster and burn my hand Sent from my DROID BIONIC using Tapatalk 2
I just had a tractor last week, with an extremely hot line. It was caused by a bad spool valve internally. The hydraulic pump NEVER shut down from it's max output. That particular line 'buzzed' the whole time the tractor was running... even when the valve was 'closed'.... Lets just say it took out the pump too! I've been taught that when a liquid is forced through a small area, it creates heat. A lot of heat...and that heat just goes back to a tiny little reservoir to start all over again. Internal leaks on all my powershift tractors are the death knoll.... anyone have a high pressure washer? what happens when you don't trigger the wand after about 30 seconds? It causes the thermal overload to dump some water out of the head of the pump... and that little burp is quite warm! otherwise it just keeps recyling the water through the head and bypass valve until needed at the wand.I have a suspicion that yes my pump is shot, or close to it, and my boost o rings are all hogged out from the heat circulating though it like crazy...I'll have a good idea tomorrow!
