911 help!!! Clutch slave problems
I'm helping a buddy with his 1998 3500. Has the nv4500 on it. How and the heck do you bleed out the slave cylinder? I can't find any thing on it to bleed it with. [ATTACH]4518[/ATTACH][ATTACH]4519[/ATTACH]Thanks for the help!
  • Replies 4
  • Views 2.9k
The way we ended up doing on a friends truck was hook line to slave up and before installing hold slave upright with line towards the top leave cap off master cylinder and pump the hell outta it air will eventually work up towards top might be better ways to do it but worked for usForgot to mention we also filled it up before hooking the line up
I haven't messed with the one of those clutch setups before but, I have bleed brakes that you couldn't get the bleeder screws loose before by pushing down the pedal and loosening the line instead of the bleeder. If you haven't got it bleed yet, that's what I would try.
Dripley is right the whole unit has to be removed and bled hanging vertical to remove all air.
