Need Help....Transfer Case
Well i changed my output shaft seal on the NV5600 and when everything was bolted back up and fluid filled in the TC the TC doesnt wana shift out of 2wd. The shifter does not wana budge. Truck went into gear and had no issue there but cant engage 4x4 or put it in N. Did i do something wrong?? Please help me out.Thanks
99,I put an answer on the other site too, but I don't think you clobbered anything in the TC, you just may not have the TC shifter adjusted properly.Disconnect the shifter and move the TC input by hand and make sure it will go in the different positions. if it does, then the problem is definitely external.Hag
