How to check vp44 wiretap
Checking the other end being the point where it gets joined to another wire or the end of the other end?:think: Either way, as stated it should be at battery voltage with the key on....Which reminds me to check my own again, its been awhile since I have done so. oops.:banghead:
The edge comp. It is how it does it's magic.
The Wire taps do not have anything to do with the ECM. The wire tap is just a wire that taps or tees into the VP44 pump solenoid. The solenoid opens and closes a valve that sends fuel to the injectors. The fueling module that taps into this solenoid wire does not alter the original signal it receives from the ECM but rather builds a larger signal ahead of it and behind it. The wire tap allows for an increase in timing advance by adding an addtional signal ahead of the original and can add duration by adding an addtional signal behind the original signal. This is all done seamlessly so as to trick the solenoid into seeing one earlier and/or longer signal. There is still only one injector firing event. The wire tap can only build around the original signal and not alter it. They are a piggy back method of additional fueling - they are only building on top of what is already there. The wire tap boxes are somewhat complex and require input from the ECM and engine sensors to be able to be able to dynamically control the signal it sends to the solenoid.
Found it here, more info there but eh, thats the gist.
Weird
0 volts.
No lights on edge module.
But monitor works and egt works and turbo cooldown works
Need to call edge I guess
12V comes from the VP44 pump wire not the Edge Juice... So your posi-tap is worthless.
Monitor, EGT's, and turbo cooldown have nothing to do with the wire tap. That all ignition key signal and meaningless.
http-~~-//youtu.be/8Vj9n5Ee88U
Good to know - that may explain the 0 volts. But then I assume the vp44 always has 12v - so then how to know if the juice is sending.
But that would indicate the juice module is working - else cooldown wouldnt work correct ?
My concern is that they have no voltage and maybe its something in the wire/tap so they could take the stealth plate off and check for voltage with a multimeter and then check resistance from the end of the wire to the end of the wire tap. Or something.
So after the stealth plate mention and reading the install instructions again I decided to screw it down another full turn - wholla - 12v .... More importantly 55-60psi in seconds before I get out of it. !!! Turns out I must have been running untapped since the new injectors Crazy power
