CR Fuel Pressure Loss at 30% or more load.
Hanno
Hi there.
Enjoyed the interesting articles.Posted Image
:stuned: I have 2006 that looses RP under load while
the lift pump holds 12-14 PSI at all times.
Evidently the CP3 is able to produce 22-23000 psi
but not the volume the rail needs since it
sinks to 2000-3000psi under load.
Ordered a new FCA Solinoid at genos
Any Ideas ?
Michael, his post says 12-14 psi from the lift pump at all times.. makes me think he has a gauge?If the LP pressure is good and the rail pressure drops, then it's probably something with the CP3. Does it run like crap when the pressure drops?Pressure and volume are directly related, so if the volume isn't there then neither will the pressure. FCA is a good start, are you throwing any codes?What are you using to read all the pressures? Where is the LP pressure sender at, pre or post filters?
Installed the fuel pressure gauge at the filter and it it still like i said at 12-14psi under all conditions.
RP is messured with a CTS.
As the pressure drops i notice (of course) a lack of power. No missfiring etc though.
Codes are PO 148 (fuel del. problem)
The Cp 3 can produce the pressure (22.5K) but not the volume (only 30-40%)
I'l install the new FCA today after i obtain a 3.5mm L wrench
- - - Updated - - -
Ah... I think you are the German from California right? :think:
If so the what I'm thinking is the lift pump is either wore out or the pickup screen in the tank is plugged up. He doesn't have a fuel pressure gauge either.
I am the German-
I thought 12 to 14 psi is sufficiant.
Some guys are at 5 psi
If it's not the FCA it's the CP3
Installed the fuel pressure gauge at the filter and it it still like i said at 12-14psi under all conditions. RP is messured with a CTS. As the pressure drops i notice (of course) a lack of power. No missfiring etc though. Codes are PO 148 (fuel del. problem) The Cp 3 can produce the pressure (22.5K) but not the volume (only 30-40%) I'l install the new FCA today after i obtain a 3.5mm L wrench
Which side of the filter is the pressure transducer on? You are building 22.5K psi at 30-40% load? Like I said pressure and volume are directly related, if you have pressure you have volume, no pressure means no volume. Pressure is a byproduct of volume. Your pressure but not volume comment is confusing me, when are you able to see 22.5K psi?
Geno's saved the day- (a tip from Michael)
The new FCA solved all the problems !!!
The 22 K psi FRP at idle is gone :hyper: at idle I have now the normal 7000 psi
and so is the pressure drop off (FRP down to 2k psi under load).
Thanks everyone !
- - - Updated - - -
Bump. What did you find out???:shrug:
Just changing one part- the FCA
solved both problems.
thanks
