- Replies 6
- Views 1.6k
Mopar1973Man 3 posts
ISX 1 post
dripley 1 post
CUMMINSDIESELPWR 1 post
so a local shop does full rebuilds on turbos for appx $350. imma get the turbos rebuilt and have a good spare.
Hi Randy,
For an HX35W, the starting rate for a rebuild on this turbocharger is
$350.00. The $350.00 includes all new bearing, seals, bolts, thrust
bearing, thrust collar and new clamps. We test your actuator to make sure
it is within spec. We will check for shaft straightness to make sure it is
a completely level surface. All the housings (Compressor, turbine &
bearing) are all placed in ultrasonic cleaners. Then they are bead blasted
and glass blasted as well. They will then be sent back into the sonic
cleaners once more to make sure all of the blast material is out of them.
The bearing housing then gets honed and the other housings coated. The
turbine wheel gets polished and then re-balanced with the compressor wheel.
Then the unit will be re assembled.
If we find anything out of spec that we do not feel comfortable using, such
as a housing and or wheel, we will price it out for replacement of that part
or give you the option of how you want to further pursue the rebuild.
Please contact me if you have any further questions,
Thanks
Mackenzie Flynn
Turbocharger Product Manager
Phone: (303) 428-3611 Ext: 205
Fax: (303) 428-6785
E-mail: mflynn@centralmotivepower.com
Facebook:https://www.facebook.com/CentralMotivePower
mods if anything needs to be removed let me know?
