Transmission problems at initial starup ?
- Replies 7
- Views 2.3k
Rogan 2 posts
mariner 2 posts
dripley 1 post
CTcummins24V 1 post
Hi Guys,I have a situation where the truck once started (starts very easily) and I start to move off, it will often not change from 1st gear though the engine revs up (2002 auto tranny 57RE). Consequently, the truck moves at maybe 30kph. I have found that if I pull over, put the trans in park and shut the engine off and leave it for a minute or so and then restart and put it into drive, the truck will drive away normally, shifting through the gears as if nothing had happened. For the rest of the day the truck acts and performs normally.I have no codes show up and I have around 12 psi at idle and maybe 9psi at speed.Anyone have any ideas as to what is happening. Should I re-adjust the front bands - they were done about 20,000km ago when the tranny was serviced.Otherwise the truck and engine perform normally with no other problems.Any input from you experinced guys would be greatly appreciated.Thanksmariner2002 3500 auto 4x4 QC long box
